Particle/Injection Questions
Old   January 24, 2012, 21:31
Default Particle/Injection Questions
John
Mr. CFD is on a distinguished road
Hey all, I've got some questions about the dpm model in Fluent. First, how can I get the particle ID number when using the macro DEFINE_DPM_INJECTION_INIT? I want to base the particle velocity on the ID number, but apparently p->part_id is not included in this macro (returns a value of -1 when I tried it). I also tried putting Tracked_Particle *tp along with Particle *p and this didn't work either.
Next, I have set up a group injection in which I am injecting a specific amount of particles all at once. I set the start and stop time to 0, make the amount of streams equal to the total number of particles, and set different values for the first and last point z position, based on some experimental data. The question is, how do I specify the flow rate? I believe it is particle mass / particle time step. Is this correct?
Lastly, I have been having some convergence issues. I suspect it is related to the fact that I set the drag force equal to 0 (through DEFINE_DPM_DRAG) in the beginning until a specified time, and the discrete phase and continuous phase are coupled. I don't remember having any problems before, when I was simply calculating the drag with this macro and returning it to Fluent. Any thoughts on this?
Any help is greatly appreciated!
Mr. CFD is offline   Reply With Quote
dpm, flow rate, injection, particle id
Wall functions - questions about implementation AlmostSurelyRob OpenFOAM Programming & Development 44 May 6, 2020 10:11
possible interview questions atturh Main CFD Forum 1 February 21, 2012 08:53
NACA0012 Validation Case Questions ozzythewise Main CFD Forum 3 August 3, 2010 14:39
Few questions phi FLUENT 0 March 4, 2005 09:23
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 04:24
