Question on Turbulence Intensity
Old   June 24, 2008, 11:48
Default Question on Turbulence Intensity
Eric
Dear all, I am really confused with the definition of turbulence intensity. In WIKI it is described as following: 1. High-turbulence case: High-speed flow inside complex geometries like heat-exchangers and flow inside rotating machinery (turbines and compressors). Typically the turbulence intensity is between 5% and 20%
2. Medium-turbulence case: Flow in not-so-complex devices like large pipes, ventilation flows etc. or low speed flows (low Reynolds number). Typically the turbulence intensity is between 1% and 5%
3. Low-turbulence case: Flow originating from a fluid that stands still, like external flow across cars, submarines and aircrafts. Very high-quality wind-tunnels can also reach really low turbulence levels. Typically the turbulence intensity is very low, well below 1%.
So according to what presented above, turbulence intensity increases with increasing velocity, for a pipe flow which means larger Renold number larger turbulence intensity. right? We know that, however, for a fully developed pipe flow the turbulence intensity at the core can be estimated as:
I = 0.16 *(Re_dh)^{-1/8} based on this equation, why a larger Re means smaller turbulence Intensity???
And what confuses me more is Fluent Report. After solution converged, when i report turbulence intensity by Area-Weighted Average, i got 400%!! How could it be??
Your help will be really appreciated.
Regards, Eric
Old   March 7, 2012, 04:30
Default Laminar flow at inlet and turbulence due to rotary motion of the impeller
M N Gopinath
GOPINATH87 is on a distinguished road
Send a message via Yahoo to GOPINATH87
How can I specify turbulent intensity for Re = 1400 at the inlet of stirred reactor operating at high rpm...
What happens if there is a Laminar flow at fluid inlet and turbulence due to rotary motion of the impeller (MRF method)
M N Gopinath
Student
M.Tech -Petroleum Refining and Petrochemicals
Anna University
Chennai, India
GOPINATH87 is offline   Reply With Quote
Turbulence Intensity Michael FLUENT 4 August 5, 2008 14:22
Turbulence intensity?? KC Siemens 0 July 19, 2007 18:41
Turbulence intensity BC Ralf Schmidt FLUENT 3 June 30, 2006 04:17
Question...Turbulence Intensity & Viscosity ratio Jay FLUENT 1 October 6, 2005 04:41
Turbulence Intensity Luis FLUENT 2 June 28, 2005 14:29
