Is density-based solver slower than pressure-based one?
Old   February 9, 2011, 11:26
Default Is density-based solver slower than pressure-based one?
Renold is on a distinguished road
Hi guys,
I tried two same cases using density-based solver and pressure-based solver respectively and found that the simulation time of the density-based one is 3 times as much as the pressure-based one. Is this normal or I made some mistakes?
Thank you.
Renold
Renold is offline   Reply With Quote
Old   February 9, 2011, 14:59
Rokk is on a distinguished road
yes it is normal. You should get more or less the same results, however the density based in slower. They differ in the way the fluid equations are numerically solved.
Said that, density based are very useful and suitable for supersonic flows. If your problem is not supersonic, pressure-based will do.
cheers
rokk
Rokk is offline   Reply With Quote
Pressure based and Density based Solver Xobile Main CFD Forum 39 August 19, 2020 06:04
NRBC and pressure based solver ageorg FLUENT 1 August 28, 2009 07:11
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
Pressure vs Density based CFD solvers Danie Main CFD Forum 0 October 5, 2004 09:48
Density based codes? H.S.Muralidhara Main CFD Forum 3 May 28, 1999 06:29
