movements setting of the valve
Old   March 14, 2011, 19:08
Question movements setting of the valve
ZHAOHUI
Zhaohui Lu is on a distinguished road
There is a valve between two chambers. when simulating, the valve should be set to close to open and open to close slowly.
My first try is to simplify the valve movement as suddenly open and close. So I just changed the pressure outlet to wall and wall to outlet.but what happened is if I set that between the chambers, the liquid could not flow from one chamber to another.There should be a better way to slove this problem.
Is there anybody has related experience about this? I would appreciate a lot, if you could help me to figuire this problem out!
Thanks!
Zhao
Zhaohui Lu is offline   Reply With Quote
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
How to simulate valve with pressure BC? Luk FLUENT 8 June 20, 2006 08:06
Warning 097- AB Siemens 6 November 15, 2004 04:41
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Valve Forces in CFdesign Mike Clapp Main CFD Forum 3 March 8, 2001 14:09
