March 17, 2011, 14:08 |
Mass flowrate convergence error
Tariq
Hi, what I'm simulating is a regenerative pump using multiple rotating reference frames. Its a simple pump casing and rotating impeller system. I've specified the outlet/inlet of the pump as pressure outlet/inlet, and started off with a 4 psi pressure rise through the pump. I'm using the realizable k epsilon model, with non-equilibrium wall conditions. I have the solver set as second order, SIMPLE and PRESTO! I ran the simulation , with a monitor at the outlet for mass flowrate. I received a "solution is converged" message, but my mass flow at the outlet has not levelled out, in fact it just continues to increase steadily as the calculation goes on. Any ideas on how to achieve convergence on the mass flow, could a poor quality mesh be causing issues maybe?
March 18, 2011, 02:14 |
Maxime Perelli
Rep Power: 41 |
Solve Monitors Residual...
disable all check convergence And let iterate untill your massflow converges
In memory of my friend Hervé: CFD engineer & freerider |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 20:23 |
error while running paraFoam! | padmanathan | OpenFOAM | 9 | October 13, 2009 05:17 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
