Dynamic mesh parameters
Old   March 20, 2011, 04:59
Default Dynamic mesh parameters
Atze is on a distinguished road
Hi all,
i've to simulate a body rotating in a open field. My problem is that using dynamic mesh (wall set as rigid body motion) the elements degrade really fast becoming more and more larger.
I'm using fluent 13, unstructured grid (tri - 2D) with no boundary layer (prismatic layer) on walls.
I think there is something wrong in remeshing setting. Any advice?
Thank you
Atze is offline   Reply With Quote
Old   April 1, 2011, 00:27
Post
Felix
didiean is on a distinguished road
Originally Posted by Atze View Post
Hi all,
Thank you
The size function of the remeshing and smoothing may be helpful.
AND I wonder whether your steady simulating results of stationary rigid body using the same unstructured grid are similar to those of the experiment or results using structured grids.
didiean is offline   Reply With Quote
Dynamic mesh in Fluent to study tire in contact with road surface lihuang FLUENT 10 March 8, 2011 10:21
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Some questions about mesh updating in dynamic mesh technique lzgwhy Main CFD Forum 0 June 14, 2009 08:01
Help: Is it possible to use dynamic mesh model and Valery Ponyavin FLUENT 1 September 20, 2003 14:18
Dynamic mesh Phil FLUENT 1 June 15, 2003 04:57
