i need help
Old   April 7, 2011, 15:12
Default i need help
rose
rubis is on a distinguished road
hi ,
please help i have this udf
#include <udf.h>
DEFINE_PROPERTY (dyn_surf_tension, cell, thread)
real dst;
real t=CURRENT_TIME;
dst=141121*pow(t,5) - 38978*pow(t,4) + 3817.5*pow(t,3) - 148.84*pow(t,2) +
1.3033*pow(t,1) + 0.071;
return dst;
How do I get the dst versus time?????please answer me
rubis is offline   Reply With Quote
Old   April 8, 2011, 02:49
Amir's Avatar
Amir
Amir is on a distinguished road
Hi rose,
you can set volume monitor during iteration:
solve->monitors->volume .....
Amir is offline   Reply With Quote
Old   April 8, 2011, 06:59
Default display dst
rose
thank you Amir ;
but in solve---monitor---volume I did not find dst in field variable and my second question for dst what is the type of the rapport ?
cordially
Old   April 8, 2011, 10:16
Amir's Avatar
Amir
you should select properties in field variable panel and select your desired one in sub division panel that you wrote UDF for.
because your field variable hasn't spatial dependencies, so you would achieve same results if you select min or max or volume average.
regards,
