Can't run gambit ...
Old   April 15, 2011, 04:50
Default Can't run gambit ...
Vishnu R
vishnujbr is on a distinguished road
Respected friends,
first of all let me tell u first that i'm a total new guy into this fluent/gambit or any other cfd based s/ws.
coming to the problem:
i've installed fluent 6.1, gambit 2.0.4 and hummingbird exceed as per the instructions.
but the problem is i cant run gambit, whenever i opens the application , its throwing an error called SIGSEGV and closing almost instantly.
i'm using windows 7 64-bit os.
if anybody knows the solution , pls share with me....
Also if its a compatible problem pls suggest me the recommended versions of gambit.
cheers,
vish.
vishnujbr is offline   Reply With Quote
Old   April 15, 2011, 15:38
Unhappy
Vishnu R
i tried through exceed and also did through cmd prompt
when i run gambit through exceed its showing 'segmentation violation'
and when i did through cmd prompt its showing something like 'unable to find the exceed x server'
what to do now??? how do i set the xserver???
pls reply
Gambit Startup Window Jay Shim FLUENT 2 February 12, 2015 14:05
Installation of gambit Sangeeta FLUENT 4 December 10, 2008 03:40
Cycling a transient run Chetan Mistry Phoenics 0 March 3, 2004 09:50
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 03:10
Generating big meshes with GAMBIT on NT Andrew Ooi FLUENT 12 February 2, 2000 22:26
