Drag forces
Like Tree1Likes
  • 1 Post By saclu
Old   May 16, 2011, 02:43
Default Drag forces
amrit
CFDstudent123 is on a distinguished road
hii.can anybody tell me how to calculate pressure drag and skin friction drag seperately in fluent
CFDstudent123 is offline   Reply With Quote
Old   May 16, 2011, 08:47
Amir's Avatar
Amir
Amir is on a distinguished road
report->forces (set the drag direction ....)
Amir is offline   Reply With Quote
Old   May 16, 2011, 09:34
amrit
thanks for reply..but from moniter forces ..we can find the total drag.but i need to calculate the pressure drag and the skin friction drag seperately
Old   May 16, 2011, 09:44
saclu is on a distinguished road
if you want both don't use the drag monitor but
Report> forces, be careful to the director vector (give right values for X and Y). This will give you the pressure and viscous forces in the monitor
saclu is offline   Reply With Quote
Old   May 16, 2011, 09:53
amrit
can you plz tell me that what will be the value of X any Y for pressure and Viscous Drag
Old   May 16, 2011, 10:35
eddy
shimmyya is on a distinguished road
pressure should be same vector as flow direction
shimmyya is offline   Reply With Quote
Old   May 16, 2011, 10:43
What is your geometry and flow parameters?
Old   May 17, 2011, 00:55
amrit
i have a semi circular cylinder in a rectangular shaped domain . the left BC is velocity inlet , the right is velocity outlet and the top and bottom is symmetric.and its in 2D.
plz help me
Old   May 17, 2011, 09:12
You can have a look to this link, it's an example for an airfoil
https://confluence.cornell.edu/displ...+Specification
you will find how to proceed...
Old   May 17, 2011, 11:20
amrit
@saclu ..thanks for the reply..but here in the sample problem they have fount the lift coefficient and drag coefficient ...by changing the force vector.but i need to find the coefficient of pressure drag and coefficient of skin friction drag separately....
Old   May 18, 2011, 02:57
the example was just to show you how to find the right values for the drag direction vector (X et Y). Once you have these values go in Report>force, choose the the wall zone, completed the direction vector with the values you calculated then press print and you will have the pressure and viscuous force separetly on your monitor.
CFDstudent123 likes this.
Old   May 19, 2011, 03:15
amrit
@saclu...hi your reply was very useful to me ..but now i need to find the time average value of coefficent of pressure drag....and i am solving for an unsteady state problem
Old   May 20, 2011, 04:44
I wouldn't know how to do without using a UDF (User Defined Function) but it isn't a good idea if your not familiar with it. May be you could have an approximate value by solving a steady problem.
Old   May 23, 2011, 08:03
amrit
@saclu ..can u plz help me in the UDF part ...
plz tell me which function is used to get the pressure drag for writing the UDF
Plot drag forces at porous jump boundary condition Shim FLUENT 1 June 5, 2017 04:31
Drag forces on a cylinder saisanthoshm88 CFX 1 November 20, 2010 06:09
using forces for geting drag and lift force magnitude? 510_ Main CFD Forum 2 October 28, 2010 11:42
Forces and drag coeffs in simpleFoam milos OpenFOAM Post-Processing 7 December 16, 2009 09:49
Free surface drag forces New1 FLUENT 0 March 7, 2002 17:17
