Time step for unsteady simulation
Old   June 29, 2011, 05:18
Default Time step for unsteady simulation
Mohankumar.G
Mohankumarg12 is on a distinguished road
Hi
I am doing a simulation for defrosting of wind shield using fluent 12.1. In the input I am giving a time dependent temperature profile for 40min. For the unsteady calculation I am giving a time step of 5 sec and with intermediate iteration of 5.
I am also getting solution for time step of 10 sec and I am getting a quicker solution as compare with 5 sec, but I want to know which is right and how to decide the time step for unsteady simulation.
Thanks in advance.
Mohan.G
Mohankumarg12 is offline   Reply With Quote
Old   July 2, 2011, 14:40
Nik
nikhil is on a distinguished road
I would suggest, Monitor the temperature or the heat flux from the wind shield after a particular time interval.
If the difference between these monitored parameters is within some desired critera, say 5-8%, then you can trust the results of the 10 second case.
Another way to deside whether your time step is correct as per grid and convection-diffusion of your physical problem is to check
1. CFL condition OR 2. Grid Fourier Number criterion ( Depending upon a physics of your problem)
CFD criterion needs to be satisfied for negligible diffusion.
Grid Fourier number criterion needs to be satisfied for negligible convection
nikhil is offline   Reply With Quote
Old   July 3, 2011, 23:51
Mohankumar.G
Thank you Nikhil
Old   July 4, 2011, 15:03
mecamor
mecamor is on a distinguished road
hello I wanted to see the shock wave generated by a piston. My problem I can not even move my piston with moving wall. thank you for helping me
mecamor is offline   Reply With Quote
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Time step in Transient simulation sandisk FLUENT 2 February 2, 2011 23:55
Long time CHT transient simulation time step.... JP CFX 0 May 9, 2008 03:36
