What kind of mesh to use for cylindrical object in channel
Old   October 31, 2011, 21:05
Default What kind of mesh to use for cylindrical object in channel
Naser Imran Hossain
nihossain is on a distinguished road
Hi, I'm trying to simulate flow around a cylindrical 'Turbulence Enhancer' in a simple channel. I'm trying to mesh the faces and edges using Gambit's built in hexahedral meshing technique. However, I'd need to refine mesh around the cylinder wall to get better outputs. Can anyone suggest the steps needed to do that? Or do you guys think that I should use a different mesh type, like a tetrahedral mesh or something?
Oh, btw, it's a two dimensional problem. I've defined the cylinder as a circular object at the center of the channel by subtracting the circle from the channel face. Is that the right way of doing this? Or should I keep the circular cylinder edge intact and define it as a 'wall boundary' condition?
nihossain is offline   Reply With Quote
Old   November 2, 2011, 01:16
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
post pictures
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
A question on adaptive remeshing or mesh deformation for handling object motions daveatstyacht OpenFOAM 10 November 13, 2010 09:29
Mesh Mignard FLUENT 2 March 22, 2000 05:12
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
