Combustion Issue
Old   June 17, 2011, 10:23
Default Combustion Issue
Dylan Kowalewski
dkowalewski is on a distinguished road
I am trying to model a wood combustion process using species transport with a wood volatiles-air mixture. I am having a few troubles though.
First, what sort of mass flow rate should I use? I haven't been able to find any papers that show how much volatiles are being released from the wood.
Second, I am trying to implement the wood drying process by including an h2o<l> -> h2o equation, however, when I add liquid water to my mixture it doesn't appear in the species tab for the boundary conditions. Any tips would be appreciated.
Thanks
dkowalewski is offline   Reply With Quote
Old   June 20, 2011, 02:16
Piotrek is on a distinguished road
Dear Dylan,
Regadring your second problem. When using species transport with "n" species your input contains only "n-1" species. The last one is added to have sum of concentrations =1, thus satisfying the mass balance. If you add the h2o<l> as last species it will not appear in your bc. It is a standard practice to have the species arranged in your mixture list such that the one with the highest concentration (usually N2) is the last on the list.
I cannot help you with wood combustion.
Good luck
Piotrek is offline   Reply With Quote
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
2-D coal combustion -burnout issue sam FLUENT 1 November 1, 2013 00:35
hydrocarbon gases + Boron particle combustion nileshjrane OpenFOAM 1 December 13, 2010 06:20
Hydrogen Air combustion in a combustion chamber popi CFX 7 July 11, 2007 18:40
Need Similar Combustion Tutorial as my model Arnab Siemens 0 May 24, 2005 18:23
