Check case help
Old   June 27, 2011, 16:33
Default Check case help
J. Robbins
jarobbins3 is on a distinguished road
hey guys im getting this error for check case..
"maximum cell skewness is greater than 0.98. consider improving the mesh quality before proceeding with your simulation."
also in the text window
"skewness exceeded 0.98 at 15 cells on thread ID = 3.Skewness exceeded 0.98 at 15 cells on thread ID = 3."
can anyone explain:
-What it cell skewness is?
-if this is causing in major errors in the caculations?
-and possible solutoins.
thanks!
jarobbins3 is offline   Reply With Quote
Old   June 28, 2011, 01:23
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
your mesh contains cells with poor quality.
http://my.fit.edu/itresources/manual...equiangle_skew
Fix this issue by modifiying topology (merge,split, etc...) and/or remeshing
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 30, 2011, 10:21
Adrien Lemoine
AdrienL is on a distinguished road
A simulation with cell skewness greater than 0.98 will run but will give awful results such as acceleration of the flow in the middle of nowhere.
You should thing about remeshing the surface mesh (surface skewness < 0.5 will help you to have a cell skewness < 0.9), or using tools such as auto node move (in Tgrid 3d)
Adrien
Btw, to have good results the cell skewness should be less than 0.9 at least
Plz add reputation if the answer is correct
A cœur vaillant rien d'impossible
AdrienL is offline   Reply With Quote
Old   June 30, 2011, 11:55
J. Robbins
Thanks for the help, im using workbench to generate my mesh. What are there imputs that are variable to limit the skewness?
Old   June 30, 2011, 16:43
Adrien Lemoine
Sorry, can't help you with workbench. I never used it, but you have to make your triangular mesh as equilateral as possible and then the cell skewness will be good too
check case, mesh
use batch mode to run an unsteady case PaulineP FLUENT 9 April 4, 2019 08:18
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
[snappyHexMesh] Editing the motorBike case, loading diffirent .stl btgyd OpenFOAM Meshing & Mesh Conversion 1 September 26, 2011 17:24
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
