Drag coefficient error
Old   July 12, 2011, 02:01
Default Drag coefficient error
Josh
jsuf is on a distinguished road
Hi all,
I'm relatively new to CFD and could use a few pointers on my following problem.
I'm using Gambit 2.4.6 to generate a NACA0006 airfoil then Fluent 13 to calculate lift and drag coefficients at several angles of attack. Reynolds number is 3e6, laminar model, pressure based solver.
I have refined the mesh several times and have converged on a lift and drag value for each case. Comparing to Xfoil and 'Theory of Wing Sections' my lift is in the order of 2-7% accurate but for almost every case my drag is approximately double.
I've tried to refine the mesh further close to the airfoil surface but after a certain level of refinement my continuity residual no longer converges.
Thoughts?
Regards,
Josh
jsuf is offline   Reply With Quote
Old   July 13, 2011, 16:12
Ryne
Rhyno466 is on a distinguished road
What turbulence model are you using?
Rhyno466 is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
