transient converging, but not steady
Old   July 21, 2011, 18:21
Default transient converging, but not steady
PHS- is on a distinguished road
I everybody!
I am currently working on a CFD-simulation of a Solar Tower Plant (that produce renewable solar electricity: the sun heats up the air which rises in the chimney through turbines)
The transient simulation is converging (temperature, pressure, and velocity remains stable after a few time step)
A steady simulation should also been converging but it's not! (no matter what turbulence model I try)
Has anyone already seen such a problem, and could give me some advice?
PHS- is offline   Reply With Quote
Old   July 22, 2011, 14:14
Nik
nikhil is on a distinguished road
Are you trying to run the steady state with the initial/boundary conditions that are equivalent to the last flow time from your transient simulation?
If so, you should be getting the same results. If you are running the steady simulation with different BC/IC, then you may get different solution
nikhil is offline   Reply With Quote
Old   July 22, 2011, 14:29
Thanks for your answer!
I tried to run the transient simulation until I get convergence, and then to turn on the steady calculation without initialising (since the solution has already converged, steady calculation should work).
But when I do that, it's diverging, for example the temperature was stable for 2000 time step at 322K, and when I turn on the steady calculation, it's oscillating very fast between 300K and 360k, and is not converging at all (even after 30000 iterations...)
Old   July 24, 2011, 12:58
Micael
Micael is on a distinguished road
Did you try to decrease the under-relaxation factor of energy equation? From 1 to 0.8 as an example?
Micael is offline   Reply With Quote
Old   July 24, 2011, 20:59
yep, but that leads to high discontinuities in temperatures: the more I decrease it, the more convergence I get, but more discontinuities appears...
(by discontinuity I mean high change in temperature on the elbow, I can "see" the meshing through the temperature contours, instead of having a smooth transition.)
Old   July 25, 2011, 14:25
jsm
JSM
jsm is on a distinguished road
I think this phenomenon is transient in nature. If you have good results in transient solver, then why are you switching back to steady state solver?
If you want quick results, then increase the time step size without decreasing convergence level.
With regards,
JSM
jsm is offline   Reply With Quote
Steady solution from Transient simulations wawa FLUENT 2 November 9, 2010 17:44
About using transient method to solve steady problems doctor evil Main CFD Forum 1 April 14, 2010 23:46
Mass Diffusion: Transient and Steady State BC rval CFX 3 November 19, 2008 00:52
Transient vs Steady State Adam CFX 1 April 12, 2007 11:34
Difference between steady and transient problems Jianping Zhang Main CFD Forum 9 April 14, 2003 06:17
