Net mass flow inlet vs outlet
Old   August 12, 2011, 08:59
Question Net mass flow inlet vs outlet
Nicolas Guillemette
Nigui28 is on a distinguished road
I simulated an open channel flow problem for a dam project using two inlets (upstream boundary conditions) and one outlet (downstream boundary condition). The total water mass flow from my 2 inlets is 330 m3/s, thus I expected to get approximately the same mass flow for my outlet which is totally logical (conservation of mass). My simulation converged very well but I found out a mass flow of 570 m3/s at my outlet which is 240 m3/s more than the mass flow that enter in the domain ??? How does the model can enter 230 m3/s more water in my domain ?? I double checked the mass flow rate of my outlet in FLUENT and in the POST and I found for both a same difference mass flow of 230 m3/s ?
I use the following parameter as model setup
- VOF with the open channel flow option checked
- Explicit solver
- mass flow rate as upstream boundary conditions (inlets)
- Specify water level as downstream boundary condition (outlet)
- Geo-reconstruct as Volume fraction solution method....default options for the other solution methods
- Outlet ventilation on the top of my domain
Is somebody as an idea why the conservation of mass is wrong for a simple simulation like this one....I really do not understand why ?
Thanks for your help !
Nicolas
Nigui28 is offline   Reply With Quote
Old   August 12, 2011, 10:09
Nicolas Guillemette
I think the best assumption to explain this mass flow difference is likely the fact that I patched with water in the initialization and this water volume (sort o wave from upstream to downstream) is now exiting the domain and give me a higher water mass flow than mass flow that enter inthe domain. I will continue to simulate and I suppose the mass flow will decrease at the outlet while all the initialization water volume will be out of the domain. Im still in the transient stage.....more time step to reach a sort of steady flow.
I answer myself but somebody can confirmed my assumptions
Thanks
Nicolas
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Mass flow inlet compressible flow richard FLUENT 2 June 1, 2008 11:44
mass flow inlet boundary condition vivian FLUENT 5 April 21, 2006 06:23
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
