August 26, 2011, 06:51 |
F_AREA returns the wrong value
Denis
Rep Power: 14 |
Hello, everyone!
Currently I'm running a multiphase axisymmetric problem. In order to calculate force on the floating body, I use following loop: begin_f_loop(f,t){ F_AREA(A,f,t); force[1] += A[1]*F_P(f,t); } end_f_loop(f,t) But F_AREA macro is returning area vectors with much higher amplitude, than is possibly (my body is just not big enough), so, even without multiplying my results by 2*Pi, as I should, according to the manual, I get unnaturally big forces acting on my body. Does anybody know how to fix it? Thanks for your time! Last edited by _Denis_; August 29, 2011 at 02:58. |
August 29, 2011, 03:00 |
Denis
Rep Power: 14 |
What? No one encountered this problem before?
August 30, 2011, 08:37 |
Abhishek
Rep Power: 15 |
F_AREA or C_VOLUME in axis symmetric should be multiplied by 2*pi - use (2 * M_PI)
Also make sure that your axis is coincident with X or Y axis... I suppose it can also cause troubles hope this helps |
September 7, 2011, 09:30 |
Denis
Rep Power: 14 |
I made sure that symmetry axis coinsides with Y, but this didn't help. I made my udf sum up the total area, and it's 5 times greater than expected.
Thank you for your reply, though. |
udf error | srihari | FLUENT | 1 | October 31, 2016 14:18 |
What's wrong? Non-conform mesh problem!!! | Neo | FLUENT | 1 | March 31, 2013 15:00 |
BuoyantBoussinesqSimpleFoam and axial-symmetric results wrong mass flow | Thomas Baumann | OpenFOAM | 6 | December 21, 2009 10:31 |
CrankNicholson returns wrong dimensions and sound speed when mesh is moving | lillberg | OpenFOAM Bugs | 6 | May 4, 2009 17:53 |
Pressure contour seems wrong??? | Harry Qiu | FLUENT | 1 | June 29, 2001 05:53 |
