Causes for Drag over prediction in 2D flow
Old   August 7, 2011, 10:13
Default Causes for Drag over prediction in 2D flow
Mike
josip76 is on a distinguished road
In examining a 2D transonic airfoil I've found my lift is dead on (error of 0.55%) but my drag in error by 18% (over predicted). Now from my understanding the drag in FLUENT is calculated by directly integrating the pressure and skin friction forces. Because the lift is being accuratly calculated and the shock position being accurately predicted im assuming that the wave drag is acutely predicted. So I'm attributing my error to the lack of resolution of the viscous drag (pressure and skin friction drag). But because the lift is mainly due to the pressure difference which again I gather is calculated by integrating the pressure forces on the upper and lower surfaces and differenceing, the pressure drag which is due to pressure imbalances would be correct indicating an error in the calculation of the shear stress?
I attributed these errors in turn to the high aspect ratio and skew in the grid. So with the high Re of the flow the boundary layer is tiny causing high aspect ratio cells near the wall. The dissimilar scales of motion in the normal and streamwise directions introduces numerical stiffness into the algorithm. Additionally, the discretization I used is second-order accurate, which is actually only formally second order accurate on smooth grids, the grid i used had stretching and skewness which I said produced high truncation errors leading to excessive dissipation?
Am I on the right track here in understanding where my drag error came from and the root cause of them?
Thanks
josip76 is offline   Reply With Quote
Old   September 20, 2011, 09:18
Centurion2011's Avatar
Centurion2011 will become famous soon enough
komplikuješ Josipe brate
Centurion2011 is offline   Reply With Quote
2 dimensional, 2-d, drag
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
volume flow prediction in a fan yochule FLUENT 0 March 17, 2009 10:05
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
PhD in turbulence Hans Main CFD Forum 14 October 8, 2001 03:03
