F_CENTROID
Like Tree2Likes
  • 2 Post By ap
Old   January 8, 2004, 20:30
Default F_CENTROID
co2
I was looking at the following simple code for a UDF.
F_CENTROID(x,f,thread); y = x[1]; F_PROFILE(f, thread, nv) = 20.*(1.- y*y/(.0745*.0745));
x is the position vector defined as: float x[3]; /* this will hold the position vector*/
Question: wouldn't y=x[1] assignment pick up the x coordinate of the face centroid? the original formula for the velocity is
u(y) = 20 [ 1 - (y/0.0745)^2]
So I was wondering if we need to write y=x[2]
Old   January 9, 2004, 01:53
Default Re: F_CENTROID
ap
No, in C all arrays starst from the 0 position. So you'll have x[0], x[1] and x[2], which contains, in the order, x, y, and z.
P.S. Better to define x as:
real x[ND_ND];
because FLUENT manages real type as a float or double according to the chosen solver.
ND_ND allows to keep the code more general because ND_ND = 2 for a 2D case and ND_ND = 3 for a 3D case.
Hi
ap
Dri and soheil_r7 like this.
Old   September 1, 2011, 01:49
Default x{nd-nd}
Nirav
niravtm007 is on a distinguished road
Send a message via Skype™ to niravtm007
please can you tell me how will the code for 3d parabolic inlet will be modified.
i have cubical section. with circular inlet of 0.1 radius on one face.
should i use x[ND_ND] & take y=x(2) as variaion will be in both directions y,z. it should be paraboloid.? please give some idea
niravtm007 is offline   Reply With Quote
