Wall Zone References
Old   September 1, 2011, 19:47
Default Wall Zone References
isk82live
isk82live is on a distinguished road
So I have a model of an airplane wing that I am trying to do a CFD test on. It goes through loading the geometry and meshing. I set up the conditions for the CFD test, then initialize and calculate. It converges the calculations perfectly. However, when I try to return to monitors for lift and drag, I cannot find a reference for the wall zones. Is there a way to manually create these before the test?
I exported the geometry form Pro/E as an .stp if that matters (I don't believe it should).
Edit: Also, I realized in the Boundary Conditions options, I was changing the wall boundary to a pressure-far-field. Is there a way to create a new pressure far field option in the Boundary Conditions options?
isk82live is offline   Reply With Quote
wall reference monitors
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation 101 September 21, 2011 05:37
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic sponiar OpenFOAM Meshing & Mesh Conversion 2 March 30, 2009 15:02
T junction - meshing wall zone in Gambit John FLUENT 3 August 29, 2005 10:09
Fluent creating wall zone on mesh import? Mark FLUENT 4 April 4, 2005 07:14
