DPM with multiple reference frame
Old   September 9, 2011, 12:22
Default DPM with multiple reference frame
Francois
Neil11 is on a distinguished road
I would like to simulate particle paths in a rotating separator including blades.
But the Fluent 6.3 User Guide says:
“When multiple reference frames are used in conjunction with the discrete phase model, the display of particle tracks will not, by default, be meaningful. Similarly, coupled discrete-phase calculations are not meaningful.”
My question is: if I run coupled DPM-continuous phase calculations with the MRF model, the results will be wrong or just the display of the particle paths?
If the results are wrong, have you a suggestion to perform correct coupled DPM simulations in a rotating device (without using the option “track in absolute frame” because it gives wrong particle-blade interactions in my case)? Should I use a moving mesh with unsteady DPM calculations?
Thx
Neil11 is offline   Reply With Quote
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 04:28
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
