GAMBIT Meshing
Old   September 27, 2011, 03:34
Question GAMBIT Meshing
ANKIT GUPTA
vit.ankit is on a distinguished road
hi,
I have designed my 3D grid in AutoCAD (digitised the geometry) and when i imported it to Gambit environment,i have 1000s of edges and faces which i want to reduce and from the wireframe (which i digitized) i cannot define my extruded AutoCAD as a volume...
Kindly advice
Regards
Ankit Gupta
CSIR-NEERI
vit.ankit is offline   Reply With Quote
Old   September 28, 2011, 01:22
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
which format did you import in Gambit?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   September 28, 2011, 01:27
Default @max
ANKIT GUPTA
.sat format (ACIS)..
Old   September 28, 2011, 01:45
-mAx-'s Avatar
Maxime Perelli
do you have the possibility to get step file?
or parasolid?
Old   September 28, 2011, 02:14
Default max
ANKIT GUPTA
no...im using autoCAD 2007....
Old   September 28, 2011, 07:05
-mAx-'s Avatar
Maxime Perelli
ok I have your geometry in front of me.
What do you want to compute?
I have some thin wall structure inside a cylinder
Old   September 28, 2011, 07:11
Default reply
ANKIT GUPTA
i want that 3D sat file to be imported to Gambit envirnment in 2D...FORMAT CAN BE ANY...
Old   September 28, 2011, 07:20
-mAx-'s Avatar
Maxime Perelli
you mean without z-extrusion?
Old   September 29, 2011, 01:33
Default @max
ANKIT GUPTA
yes..........
Old   September 29, 2011, 02:00
-mAx-'s Avatar
Maxime Perelli
If I delete the z-extrusion, it only remains the source edges.
What do you want to compute finally?
Old   September 29, 2011, 02:12
ANKIT GUPTA
i want the mesh to be a 2D model in GAMBIT so that i can sweep it along any vector....thats it...
Old   September 29, 2011, 03:09
-mAx-'s Avatar
Maxime Perelli
ok
Import your .sat into gambit
Move all your surfaces with specific vector for having your cylinder centered with your axis.
Then delete all surfaces from cylinder.
It remains only surfaces from your internal structure
Now, in delete-surface panel disable lower geometry and delete all the surfaces.
Delete all edges except the source faces from one cap (see picture)
Create one disk with your dimensions.
And now you need to split your surface with your edges.
I don't know why but you cannot select all the edges to generate your split.
So take some coffee, and pick edges one by one (you can split x-times if you want)
Once it is done, you just have to sweep your surface with your vector.
And finally go and mesh
Old   September 29, 2011, 03:49
-mAx-'s Avatar
Maxime Perelli
Wait I tried to sweep surface with some zig-zag splits, but it merge the zig-zag.
So on ce you create your disk, save your dbs.
Then merge your edges. I tried and you cannot merge all the edges on the fly, so you need to merge some series.
Once it is done sweep edge with vector (you will have your zig-zag surfaces, like your import)
Then sweep your disk, and split this volume with your zig-zag surfaces.
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 05:04
