October 11, 2011, 03:56 |
Problem with centrifugal force
Norger
Hey,
I read in this article: http://www.cfd-online.com/Forums/flu...ting-wall.html that the "centrifugal force gets calculated automatically during solution" but in my case it does not. My part is a bin which has ducts perpendicular to the rotation-axis and there should come out the fluid. The problem is that not each duct give out the fluid. The half of them push out and the other half suck in the fluid?!?! --> The centrifugal force does NOT get calculated automatically during solution. Thank you for your help |
October 12, 2011, 01:55 |
Norger
Did nobody has the same mistake?
Problem with centrifugal pump calculation | Michiel | Main CFD Forum | 2 | June 17, 2012 21:32 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
DEFINE_CG_MOTION and pressure force | Teo Fumagalli | FLUENT | 0 | April 11, 2008 10:25 |
Problem with surface pressure integrals | javier | FLUENT | 0 | February 9, 2004 15:09 |
gravitational force for free surface flow | Jongtae Kim | Main CFD Forum | 1 | July 2, 2000 11:57 |
