October 12, 2011, 06:22 |
my important question, UDF
hamid
Rep Power: 15 |
hello guys
i have a very important question, and that is: how is it possible to add some models to fluent for some special simulation, for example i want to simulate a suction of a fluid inside a tube while the fluid is attached to the wall and needs some sort of time and pressure in advance to be unattached from the wall, also when the fluid moves in the tube, it has friction to the wall (both static friction when is not moved yet and dynamic friction).... i have the anayltical model of capacitance, resistance, inductance model of fluid when the suction pressure is applied but i dont know how should i add it to fluent through UDF, ur helsp are really appreciated thank u |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
Quick question RE: UDF | Dylan | FLUENT | 2 | August 22, 2007 15:47 |
UDF question | Kerem | FLUENT | 0 | April 3, 2006 19:24 |
A question about the dynamic mesh UDF | Tango | FLUENT | 1 | November 27, 2003 02:56 |
a question about UDF | Wenbin | FLUENT | 0 | November 12, 2003 10:24 |
