appropriate BC - top half of the pipe
Old   October 31, 2011, 10:50
Default appropriate BC - top half of the pipe
Diego
Diegoesteban is on a distinguished road
Im simulating a pipe with a ke model, considering the top half of the pipe. My problem is with the boundary conditions. I set “velocity-inlet” and “pressure-outlet” for the inlet and outlet faces. What is the more appropriate BC for the symmetry plane? “symmetry” or “axis”? What is the difference?
Diegoesteban is offline   Reply With Quote
Old   November 2, 2011, 01:14
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
*symmetry means symmetric with respect of a plane
*axis means revolution-axisymmetric with respect of an axis (solution theta-independant with theta: rotation-angle around your axis)
When you are using axis, you must work with 2d solver.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 2, 2011, 07:03
Diego
thank you very much!
[DesignModeler] DesignModeler Pipe within pipe shields ANSYS Meshing & Geometry 13 November 25, 2018 22:14
fluid flow around a half burn pipe Destry FLUENT 13 July 16, 2010 21:42
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
