Premixed combution -- divergence at the first iteration
Old   April 10, 2009, 12:10
Default Premixed combution -- divergence at the first iteration
allamarein is on a distinguished road
I am trying to familiarizing with premixed combustion.
I tried to use a duct with map (it's a test geometry).
I use adiabiatic model and k-eps turbulence.
I get
"Error: divergence detected in AMG solver: premixc"
at the first iteration.
Maybe I initialize bad?
Do you have a tutorial about premixed combustion?
I's like to see a working case to understand...
allamarein is offline   Reply With Quote
Old   April 14, 2009, 04:07
anonym
Laci is on a distinguished road
I get
Have yout tried to solve it step by step? First, without reaction, just air. Then try to calculate with reaction.
Laci is offline   Reply With Quote
Old   November 13, 2011, 18:31
Default (Divergence detected in AMG solver: premixc)
Hadi
Haniii is on a distinguished road
Hi
I am trying to use premixed combustion model for a problem that I have solved it without using species. I am getting error from the first time step. "Divergence detected in AMG solver"
Divergence detected in AMG solver, primitive error at node 1" > decreasing coarsening group size"
Divergence detected in AMG solver, primitive error at node 1" > increasing relaxation sweeps"
Also afetr I tried again changing a few parameters such as W-Cycle, Max coarse relaxation and coarsed by, in the Solution Controls windowone or two parameters I got
Divergence detected in AMG solver.
Do you know how can I solve this problem ?
Thank you very much for your help
Haniii is offline   Reply With Quote
amg solver, divergence, premixc, premixed combustion
how to increase "Newton Pressure Iteration Limit" kus CFX 9 April 21, 2013 01:54
premixed flame modeling problem peiyong wang CFX 1 July 18, 2008 12:02
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 22:30
Creating, loop or iteration using expression edito Jan CFX 3 July 28, 2003 11:01
Heat exchanger problem chiseung FLUENT 16 October 20, 2001 04:36
