Boundary condition for exhaut flow with imposed mass flow |
April 25, 2011, 13:13 |
Rep Power: 15 |
I'm modeling the ventilation of a room with Fluent. At the inlet, I would like to use a velocity inlet BC. I have several outlets. I would like to impose the mass flow at these outlets. For instance, let's say I have an inlet with a mass flow equal to 1 kg/s and 2 outlets where the mass flow are equal to respectively 0.8 kg/s and 0.2 kg/s. Which BC should I use at the outlets? Can I use some velocity inlet BC at the outlets to impose the flowrate? Or should I use some pressure outlet boundaries with the target mass flow rate option? I could also use an outflow BC and adjust the flow rate weighting. What is the best approach. Thanks in advance, Stéphane |
November 24, 2011, 02:04 |
Rep Power: 17 |
I assume your flow might be compressible. If so, the outflow condition will not be applicable. The pressure outlet BC with target mass flow is a better option.
Oops, this is a late reply. Hope it helps. Regards Luke |
atio |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Target Mass Flow Rate | Nitin | FLUENT | 9 | June 17, 2017 10:30 |
External,incompressible flow boundary condition? | John | FLUENT | 2 | August 19, 2011 00:42 |
outflow boundary condition foe flow over a cylinder | Ardalan | Main CFD Forum | 0 | April 29, 2010 13:04 |
OutletBoundary Condition Causes Mass Imbalance | Andy | Main CFD Forum | 0 | March 11, 2004 14:05 |
