How to input an Arcgis map into Gambit?
Old   December 4, 2011, 20:29
Default How to input an Arcgis map into Gambit?
Isaac Yuan
eggshell is on a distinguished road
As the topic, I wish to use Gambit to analysis a lake area which is based on an Acrgis map. Is it possible to achieve and how if so?
eggshell is offline   Reply With Quote
Old   December 5, 2011, 00:46
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
check the export possibilies from your software, and compare with the import-one from gambit: http://my.fit.edu/itresources/manual...nu_file_import
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
cannot input CATIA *.model into gambit soilinkin FLUENT 10 January 12, 2011 00:47
Input datafiles into the GAMBIT Kevin FLUENT 4 June 21, 2008 05:20
Gambit map meshing scheme Juliana P FLUENT 2 October 30, 2005 15:59
Input Geometry from Ideas to Gambit Knick FLUENT 2 December 11, 2002 03:59
