Boundary Layer Across the Inlet of Nozzle
Like Tree1Likes
  • 1 Post By shk12345
Old   December 2, 2011, 05:46
Default Boundary Layer Across the Inlet of Nozzle
HLYBoy is on a distinguished road
I have a converging-diverging nozzle with 'pressure-inlet' and a 'pressure-outlet' and are using a no slip condition at the wall.
At my inlet, I have a velocity profile across it, indicating that I have some sory of boundary layer as I have a velocity profile across the inlet. But, as it is the inlet, I should not have a boundary layer because there has not been any boundary layer growth or anything.
Does any one know why this would be the case? The image shows what I mean. The x axis represents the y distance away from the centreline. There is a velocity profile when there shouldn't be one. I have also attached the velocity vectors at the inlet.
Thanks in advance!
HLYBoy is offline   Reply With Quote
Old   December 2, 2011, 06:02
Default hi
shoeb khan
shk12345 is on a distinguished road
Hi
Just try to use a very very fine mesh at the corners if you want a boundary layer at that place.
Thanks
SHK
shk12345 is offline   Reply With Quote
Old   December 2, 2011, 06:07
I meant there should not be a boundary layer at the inlet, but my case shows there is a boundary layer there because of the velocity profile. I want to find out why there is a velocity profile there, when there shouldn't be one.
Thanks
Old   December 2, 2011, 22:43
Default Hi
shoeb khan
The problem is that at inlet the flow is developing and it requires some time to come under the state of fully developed state.
Hence during that transaction period there has to increase of velocity .
There is no slip condition at the walls. Hence the velocity there is 0.But at the center of the pipe velocity has to maximum. Hence there should be a velocity profile.
I hope this may help you.
SHK
purushothge likes this.
boundary layer, fluent, inlet
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 00:35
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 01:45
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 19:23
