December 31, 2011, 02:53 |
moment defining
mohongtao
hello everyone:
I want to know how Fluent define the Moment Coefficient, Was it defined as: cm=M/(0.5*density*v*v)? or someelse form. thanks a lot! |
December 31, 2011, 05:41 |
duri
cm=M/(0.5*density*area*length*V*V), all taken from reference values.
January 3, 2012, 21:12 |
mohongtao
Duri,thanks for your attention
now,I have known that cm=M/(0.5*density*area*length*V*V), and all taken from reference values. I also use Fluent Function compute_force_and_moment to get the moment,then i used the moment to get cm, I found that this cm was diffenent from the Monitors-Force-CM, Could you tell me why? |
January 4, 2012, 12:29 |
duri
It will be same. Check moment origin, axis etc.
January 5, 2012, 03:18 |
mohongtao
I think i have misused this function, could you give me a UDF that contains this function, thank you very much!
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Applying a moment to an object | daveatstyacht | OpenFOAM | 0 | July 27, 2010 04:35 |
UDF extern variable - mean time moment coefficient | enry | Fluent UDF and Scheme Programming | 0 | November 14, 2009 06:56 |
UDF extern variable - mean time moment coefficient | enry | Fluent UDF and Scheme Programming | 0 | November 14, 2009 06:51 |
viscous moment | Thierry | FLUENT | 0 | April 8, 2003 05:43 |
