January 10, 2012, 14:32 |
prescribe pressure on inner face
Yolk
Rep Power: 14 |
hi,everybody
As the fan model build by ANSYS, I want to prescribe the pressure by myself not using fan model. Because the magitude of pressure is equal on both sides of the disk but I this is not what I want. I decide to built one face as the disk, and use udf to prescribe pressure jump to make it different on the two sides of the disk. can you tell me how I can achieve it? Best regards! Yannian |
January 10, 2012, 23:55 |
MK
Rep Power: 16 |
Dear Yannian!
really, I did not understand what exactly you want to do. generally, setting the level of pressure at inlet boundries has some limitations. the value of pressure at inlet boundaries are aften resulted from the outlet pressure value. In fan model, FLUENT asumes a pressure difference between two sides of the surface that yields to a driving force for flow. but if you set the value of pressure manually, no driving force would be generated. If you get some additional information, I would be able to help you more. |
January 11, 2012, 03:41 |
Yolk
Rep Power: 14 |
Dear takin,
The model is a propeller. I want to use disk to simulate it. The fan model used in FLUENT adopt classic actuator disk model. When I checked the pressure jump in this model I found that the pressure was prescribed the same maginute and the opposite sign, such as -5 and 5, so the pressure jump is 10. The propeller I use is not like this situation, the magnitude of pressure must be different, such as -8 and 2, the pressure jump is 10 also. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Maintaining Static Pressure at Fluid Flow Inlet | cdevalve | FLUENT | 3 | January 14, 2012 00:11 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
I want to use pressure of 1 face in udf that compiled on other face | iman_1844 | Fluent UDF and Scheme Programming | 3 | June 10, 2010 12:55 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
