January 11, 2012, 00:16 |
Courant Number
Vaibhav Rai Khare
I am using VOF model for simulating..but within 1 or 2 time step courant number reach its limit and iteration stops..i reduced the time step size from 1 to 0.05 but there is no result of it..and i have to simulate it for around 1hour..
how can it be possible to increase courant number..or what is its concept.. |
January 11, 2012, 08:10 |
Re
Domenico
may be the mesh resolution is involved in the Courant number?
regards |
January 11, 2012, 08:26 |
Vaibhav Rai Khare
thnx doronzo...but there is no role of mesh resolution..
January 12, 2012, 07:59 |
JP
Rep Power: 18 |
Did you check the flow velocity? If it is too fast through the system, it may give a problem.
Courant number = velocity * delta t / delta x It is a measure of the ratio of simulation time step to the system time scale. You can edit the Courant number limit in the solver settings. Last edited by srjp; January 12, 2012 at 08:12. Reason: to correct a spelling mistake + to add some more details. |
January 12, 2012, 08:23 |
Vaibhav Rai Khare
i have checked..there is no velocity in my model..i didn't give any..
how can i change courant number in solver? i have gave its value to 1 in VOF model solver setting but its not working |
January 13, 2012, 00:34 |
JP
Rep Power: 18 |
No velocity? What are your boundary conditions?
Also, you can still try reducing your time steps. It is always good practice to start with extremely small time steps and gradually increase it. |
January 13, 2012, 00:54 |
Vaibhav Rai Khare
Actually i am working on a water filled (30% by volume) box which is packed. there is only a pressure outlet on its upper face. The heat is given to the box by its lower surface..
Boundary Conditions Are: Fluid (water) outlet(pr outlet) plate (heat is given) i reduced time step to very small number as in VOF model the time step size should be in the form of 1e7. But after some time (10 sec) it always increase suddenly at a particular point..and its courant number reaches very high.. |
January 13, 2012, 22:52 |
Lucky
Rep Power: 66 |
May not be directly related to the problem but, interval size plays a direct role in the calculation of the Courant number so the role of mesh resolution cannot be thrown out. Mesh resolution definitely has an impact (it is in the definition of Courant number).
January 14, 2012, 05:26 |
shoeb khan
Use a time step of 1e-7 to 1e-5 and then tell me what happens.
shk |
Courant number | fireman | FLUENT | 7 | September 11, 2021 11:33 |
IcoFoam unstability, courant number gets large! | vivien | OpenFOAM | 11 | March 9, 2017 03:45 |
LES near wall model & courant number | kasim | CFX | 5 | March 16, 2008 18:23 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Courant number calculation - unsteady flow | Kuba | FLUENT | 0 | November 8, 2005 22:44 |
