Moving Mesh Fluent
Old   January 22, 2012, 05:30
Default Moving Mesh Fluent
ChrisR is on a distinguished road
Hey there!
I wanna simulate a cylinder motion in Ansys Fluent but i always get the "negative element"- error.
I got 1 rigit body call "bottom", and the sidewalls call "wall" as deforming body.
The moition works and looks like the picture below :
http://imageshack.us/photo/my-images...enannt1wy.jpg/
I'm pretty new to fluent and don't know whats my failture is
I think it looks like my wall move but my domain is stationary and thats the reason why my fluid domain is outside the walls? Correct me if i'm wrong.
I think i got a major issue in my understanding of the moving mesh :-)
Is there any good tutorial for moving mesh?
Updating solution at time level N... done.
Updating mesh at time level N...
Info: Maximum Cell Skewness outside reasonable limits, using 0.7 instead.
global conserved variables:
domain 1: ( 6.44971e-04 0.00000e+00 2.04581e-06 2.24282e-03 4.28291e-06 0.00000e+00 7.41762e-04 0.00000e+00 0.00000e+00 )
domain 1: ( 6.44971e-04 0.00000e+00 2.04581e-06 2.24282e-03 4.28291e-06 0.00000e+00 7.41762e-04 0.00000e+00 0.00000e+00 )done.
Warning: non-positive volumes exist.
Error: Update-Dynamic-Mesh failed. Negative cell volume detected.
Error Object: #f
Last edited by wyldckat; September 3, 2015 at 17:59. Reason: disabled embedded images
ChrisR is offline   Reply With Quote
Old   January 22, 2012, 16:03
Default I think i now the problem but i have no solution
Philipp Bolay
Cola1988 is on a distinguished road
Hey Dude,
I think I know your mistake.
It looks like your mesh doesn't deform. Your boundary ( piston bottom) simply moves up- and downwards. Is this assumption correct?
I think you have to couple the cylinder wall and the piston bottom to make the same movement. I think the mistake is somethng with your domain nd the moving mesh. Have you looked on re-meshin elemnts and so on?
Regards Phil
Cola1988 is offline   Reply With Quote
Old   January 22, 2012, 16:05
Correct.
How can i fix it? Does anybody know?
Old   January 24, 2012, 01:33
Sugajen
Sugajen is on a distinguished road
Hi there
I'm new to Fluent. Trying to move a piston by applying pressure. How should i do it?
Sugajen is offline   Reply With Quote
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 06:28
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
C4 = 1 for Moving Mesh Xobile Siemens 2 January 18, 2005 05:22
