surface species absorption
Old   February 7, 2012, 11:00
Default surface species absorption
gghazal is on a distinguished road
Hello !
I want to model an oxygen gas jet impacting a wall where a big part of the oxygen is absorbed (I also have other gaseous species in the system).
The wall boundary condition is the limit of my system so the idea is to set a kind off 'negative mass flow inlet'
First I tried writing a UDF where I applied (with define_adjust) a sink term on the cells near the surface
I also tried setting a negative mass flow inlet while setting the 02 mass fraction to 1. This did not work either because other gases were also absorbed.
Did any of you model this kind of problem before ?
gghazal is offline   Reply With Quote
[Gmsh] gmsh and boundary layers kanuk OpenFOAM Meshing & Mesh Conversion 11 August 14, 2015 12:35
[Gmsh] Default Faces on Boundary Layer axel OpenFOAM Meshing & Mesh Conversion 8 February 17, 2011 07:47
mass flow rate on the Iso-clip surface & interior Sunil Gupta FLUENT 0 April 22, 2008 09:29
Multiphase + Species reactions for wall surface ?? Luke FLUENT 1 June 25, 2006 09:07
Patran Volume Meshing Deb CFX 19 April 17, 2003 10:56
