Operating pressure and reference location?
Old   February 16, 2012, 08:33
Default Operating pressure and reference location?
Abhijeet Shrawage
ashrawage is on a distinguished road
Hey guys can you explain what the operating pressure and reference location does?
Could you tell me what my operating pressure and reference location would be for my system.
there is a central inlet at a pressure of 3300 PSI and 2 outlets at the same height level at a pressure of 3200 PSI on the either side of the inlet. THE INLET AND OUTLETS ARE SEPARATED by the inlet tube walls which goes 3.5m deep in a tank.
Inlet dimension 0.3m dia outlet dimensions 0.1m each or subject to change a bit.
Please let me know what my op pressures will be and the reference location?
ashrawage is offline   Reply With Quote
Old   February 18, 2012, 08:57
delaneyluke is on a distinguished road
Hi Abhijeet,
Generally you specify the operating pressure and location at a point within the domain where yu know the pressure. This needs to be specified only if you use pressure inlets with a pressure outlet. If you use a mass flow/velocity inlet then the reference location is not important.
I hope this answers your question.
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   February 18, 2012, 09:09
Default Thanks a lot Luke
Abhijeet Shrawage
Thank you for your help.
Also can you help me with another issue?
I have a a 2D version of the tank which is symmetrical about the y axis.
So I have created only half of it to decrease the cells and computation time.
As s result the inlet in the sketch is only half it's actual diameter. Do I mention full diameter in the hydraulic diameter? Or only half the actual diameter?
Thanks
Abhijeet
Old   February 18, 2012, 10:07
use the whole dia to calculate hyd dia
regard
Luke
Old   October 24, 2023, 20:42
Leo Obed Dwikyra Sibarani
leosibarani1 is on a distinguished road
What if i work in 2 fluids domain separated with a solid body. In 1 fluid domain, the outlet is atmospher with mass flow inlet. The other one use mass flow inlet and pressure outlet which is not atmosphere.
Where should i put the operating pressure reference point?
leosibarani1 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Operating pressure and Reference pressure Location-1 kamal_g65 FLUENT 0 September 16, 2010 20:52
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
