Reverse Flow
Old   February 28, 2012, 20:32
Default Reverse Flow
Musango Lungu
Musa is on a distinguished road
Hi I am simulating a gas-solid fluidized bed and I am receiving a message " reverse flow on x faces at pressure outlet y. My boundary conditions are velocity inlet and pressure outlet.
Musa is offline   Reply With Quote
Old   February 29, 2012, 01:29
Smile reversed flow
tichaona
tichaona is on a distinguished road
I have had the same message from my simulation. You can take it out by replacing your pressure outlet boundary with outflow boundary if you want to. Also reversed flow may be actually ocurring in your real problem. How many cells have the reversed flow? If the number is small when compared to total number of cells, then it does not matter much. Is the reversed flow message appearing throghout your calculations or is it just appearing initially and then disappears. If it disappears then its ok.
Hope this may help you.
tichaona is offline   Reply With Quote
Old   February 29, 2012, 01:35
Zigainer is on a distinguished road
I get reverse flow quite often with pressure outlet, but if the reverse flow dissapears ... so thats fine
Otherwise start with first order and lower under-relaxation factors for a couple of iterations and than change the relaxation factors and switch to 2nd order.
Zigainer is offline   Reply With Quote
Old   February 29, 2012, 05:17
Musango Lungu
Tichaona and Zigainer thank you for your suggestions. I will try them out
Old   February 29, 2012, 06:51
delaneyluke is on a distinguished road
Another suggestion might be to extend your outlet to a location when there is no recirculation.
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   February 29, 2012, 07:13
Musango Lungu
Delaneyluke what exactly do you mean by extending the outlet?
Old   February 29, 2012, 07:17
Extend the mesh/domain at the outlet and your outlet BC will shift to the extended outlet. This is done because it is generally unadvisable to have your outlet at a location where there is recirculating flow. But again this is done on a case-to-case basis. It depends on whether the location of recirculation at your outlet is a region of interest to your analysis. If it is not then you can ignore the reverse flow warning.
Regards
Luke
Reverse Flow Bharati FLUENT 0 September 14, 2010 01:09
Flow simulation in reverse drum mixer Patel Chirag CFX 0 July 19, 2010 15:05
reverse flow alikami FLUENT 1 June 2, 2010 04:19
Reverse flow in the VOF model yan FLUENT 1 May 26, 2005 09:14
reverse flow Giovanni FLUENT 11 October 15, 2001 03:01
