fluent solution
Old   February 28, 2012, 11:09
Default fluent solution
ajaya is on a distinguished road
respected sir
for getting fannings factor and colburn factor for counter flow concentric tube heat exchanger having helical fin on inner tube can we use udf or by using customfield function ? if it is done by udf how and if it is done by customfield function thenhow?
ajaya is offline   Reply With Quote
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
Problem in Fluent Solution - Waves on Surface Contour Richard_CFD FLUENT 0 September 8, 2010 14:39
Fluent VOF Volume of Fluid Realistic Solution Problem wormik FLUENT 3 June 21, 2009 07:04
mesh size interaction with fluent solution?? Prince Samson FLUENT 1 January 20, 2006 05:35
Generate solution (fluent) Nic FLUENT 6 February 27, 2002 11:00
