Dynamic Mesh
Old   March 11, 2012, 03:14
Default Dynamic Mesh
Spring.s is on a distinguished road
Hi
I want do modeling that the body move at one direction by layering method from dynamic mesh in FLUENT 6.3. I use the same UDF that be in User's Guide of fluent. There is one problem during simulation of this case, that the behind cells of body do not split correctly and those stretched, while the cells in front of body, colapse correctly. Despite i change the split and colapse coefficients, do not vary in solution. I will thankful everyone that help me for this problem.
Regardly
Spring.s is offline   Reply With Quote
Old   March 13, 2012, 07:03
grayback87 is on a distinguished road
try to put spring factor to 0.0.
grayback87 is offline   Reply With Quote
Old   March 13, 2012, 22:58
I use the Layering method in Dynamic Mesh with structural mesh.
Are you tell that i select spring method plus layering method?
Old   March 15, 2012, 05:04
Smile Time plot in fluent
rz
rezacfd1361 is on a distinguished road
Dear friends
I m working with fluent 6.3 ,I modelled a wave tank in fluent and I want to get time plot about the history of wave elevation at a specified point for example x=7.5,y=0.5 (in fluent I accentuate this matter again) in a wave tank with these dimensions: L=15m, H=0.8m for a detemined time domain which is smaller than wave tank modeling time domain.
if any friend know, plz guide me and give me the tips and tricks about it.
With kind regards.
rezacfd1361 is offline   Reply With Quote
Old   March 16, 2012, 03:50
it worked?
Old   March 29, 2012, 11:48
Question tracking water elevation in NWT
rz
what s the meaning of selecting sum in "define surface monitor" for "Phrases" , "volume fraction" . I have a 2 phase domain, primary phase is air and secondary phase is water. I am going to track surface changes for water, in internet i read that I have to select sum when i intoduce monitors/surface/surface monitors/define surface monitor.
my case is a Neumerical Wave Tank.
please help me.
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 08:27
pls help. mesh collapsed with dynamic mesh. wlt_1985 FLUENT 2 May 7, 2020 10:42
Incylinder dynamic mesh with volumetric reaction mas FLUENT 4 May 3, 2012 10:22
dynamic mesh on a hexa grid Manoj Kumar FLUENT 0 August 21, 2007 07:41
Dynamic mesh + grid adapt = Crash! (Files included BillH FLUENT 4 July 24, 2007 15:31
