periodic mesh copy in ICEM
Old   March 22, 2012, 02:59
Question periodic mesh copy in ICEM
Qicong Wang
ciciwang is on a distinguished road
Hi you guys, I need to generate copies of original mesh and geometry. I use the methods described below, but none of them can be imported into fluent correctly. Only original part can load into fluent, while all the copies are lost.
method(brief description):
1) translate geometry with several copies(increment the part also), loading mesh from block for original one, translate original mesh with copies, output....
2) translate geometry with several copies(increment the part also), translate original block with copies(and I cannot see the premesh of the copies), loading mesh from block, output...
Thanks
ciciwang is offline   Reply With Quote
icem mesh periodic copy
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
ICEM Tetra mesh, Size reduction and Skewness problem Catthan ANSYS Meshing & Geometry 6 December 5, 2010 19:39
ICEM 10 mesh question DAK565656 CFX 6 May 8, 2007 12:16
