gas-liquid slug flow in horizontal pipe
Like Tree7Likes
Old   March 30, 2012, 14:09
Post gas-liquid slug flow in horizontal pipe
zainab
zainab is on a distinguished road
Hello every one, I am a new member. I working on Fluent for modeling a two-phase, gas-liquid (air-water) slug flow in a pipe and I need some help please. My case: pipe length (583cm), (1.27cm) diameter, drawing and meshing by Gambit, the total elements was (112896 cell(, the pipe inlet set to (velocity-inlet), outlet to (outflow), pipe surface to (wall), the pipe continuum to (fluid). In fluent the define sequence as: 1. Solver: pressure based, unsteady, implicit scheme. 2. Multiphase: VOF. 3. Viscous: k-epsilon, standard. 4. Phases: primary as water, secondary as air, interaction: wall adhesion, surface tension (0.07). 5. Operating condition: gravity at y (-9.81), specified operating density. 6. Boundary condition: a. mixture velocity (1.6), k(0.025), epsilon(0.0072). b. air – multiphase volume fraction (1). 7. Initialize: vf=0.18, patch: air vf =0.18. I have a problem I need to get the contour of the slug vf, volume fraction? And, do I need to use a UDF for the velocity?[/FONT]
modheji likes this.
zainab is offline   Reply With Quote
Old   April 2, 2012, 00:35
Default gas-liquid slug flow in horizontal pipe
Vaze
mvee is on a distinguished road
Hi
For the dimensions specified by you, track the flow regime map and then suitable specify the velocity of the gas and water at the inlet. Patching of the secondary phase will increase the speed of the solver towards the solution, otherwise without patching run it from scratch (water filled initially) and define the velocity as a function of time; will give you various flow patterns.
Regards
mvee
mvee is offline   Reply With Quote
Old   July 27, 2012, 13:55
zainab
Originally Posted by mvee View Post
Hi
Regards
mvee
Hi mvee do you mean that i must use a user defined function for the velocity profile.
Old   August 11, 2012, 16:31
kbaker's Avatar
Khalid Baker
kbaker is on a distinguished road
Slug can obtained from stratified flow but the point of transporting stratified to slug depend on the phase velocities (especially higher gas velocity give slug flow) hence if you get stratified flow successfully just increase the gas velocity then with progress of the run with time you will get it? furthermore you need to check the range of your phase velocities that fulfill slug flow refer to any flow regime map to check it and I prefer that given by Taitel & Duckler Flow regimes map for horizontal pipes.
kbaker
modheji and hellaadouni like this.
kbaker is offline   Reply With Quote
Old   January 16, 2013, 06:43
Default to use outlet velocity in inlet
Kanarya is on a distinguished road
hi,
is ti possible to use this command in inlet where C_UDMI(c,t,2) is outlet velocity F_PROFILE(c,t,i) = C_UDMI(c,t,2);
thanks in advance!!!
modheji likes this.
Kanarya is offline   Reply With Quote
Old   January 16, 2013, 06:56
kbaker's Avatar
Khalid Baker
Vague question lead to vague answer give some details about what you want to do.
hellaadouni likes this.
Old   January 16, 2013, 07:05
thanks for quick answer!
I am simulating gas-solid flow. So I want to save velocity and volume fraction in outlet and then to use it in inlet so I managed to save it with C_UDMI but in inlet everything is zero it seems it doesnt work. here is my inlet profile:
DEFINE_PROFILE(abs_vel,t,i)
Domain *d;
cell_t c, c0;
face_t f;
Thread *ct,*t0;
begin_f_loop(f,t)
c0 = F_C0(f, t);
t0 = THREAD_T0(t);
if (C_UDMI(c0,t0,2) =0)
F_PROFILE(f,t,i)=0.001;
else
F_PROFILE(f,t,i) = C_UDMI(c0,t0,2);
end_f_loop(f,t)
thanks for your help!!!
Old   January 18, 2013, 04:16
Default help for inlet profile
Hi
is there anybody to help me?
thanks in advance!!
Old   January 18, 2013, 06:06
Yanlong Li
Yanlong Li is on a distinguished road
Hi man,
You made a mistake, do I need to correct it.
modheji likes this.
Yanlong Li is offline   Reply With Quote
Old   January 18, 2013, 06:13
Originally Posted by Yanlong Li View Post
Hi man,
hi,
yes,please...
whrere is the mistake?
I can not find it..
thanks for the answer!
Old   January 18, 2013, 08:01
Yanlong Li
this line:
if (C_UDMI(c0,t0,2) ==0)
Old   January 18, 2013, 08:07
this line:
thanks Yanlong!
I did but it still doesnt work. it seems C_UDMI doesnt work for profile...
I dont know why?
Thanks again
Old   January 18, 2013, 20:52
Yanlong Li
There was another mistake, the value you stored was the UDM of outlet, but what you used was the UDM of inlet, so you never change (or store) the value into inlet.
I have an idea, when you calculate the value of the outlet, you should get the thread (such as *tt) of inlet, if (((X_out - X_in)^2 + (Y_out - Y_in)^2) < 10^(-4))
F_UDMI(ff,tt,i) = value.
hope it can help.
Old   January 18, 2013, 23:21
Vaze
Hi Kanarya
Another way you can follow is:
(1) save the velocity profile in memory location
(2) using DEFINE_ADJUST, employ this velocity profile on inlet
Best wishes
Mvee
Old   January 19, 2013, 17:23
Hi Kanarya
Best wishes
Mvee
thanks a lot!
with DEFINE_ADJUST,it seems working now but it gives inlet very small values comparison to outlet like(solid phase mass flow rate in inlet 1.3,outlet 227) but I don't understand why?
do you have any idea?
Old   January 19, 2013, 17:26
hope it can help.
hi Yanlong Li,
thanks a lot for your help!
I think it should work without value as well..
best!thanks again
Old   January 19, 2013, 17:29
Hi Kanarya
Best wishes
Mvee
this is my inlet profile:
DEFINE_PROFILE(solid_massflow, t, i)
{ cell_t c; face_t f; Thread *ct;
begin_c_loop(c, t)
{ ct = t->t0;
F_PROFILE(c,t,i) = C_UDMI(c,ct,0);}
end_c_loop(c,t)
Old   January 20, 2013, 00:09
SSL
msaeedsadeghi is on a distinguished road
begin_c_loop(c, t)
{ ct = t->t0;
end_c_loop(c,t)
In PROFILE UDFs you should use face not cells. Correct this UDF.
cell_t c;
face_t f; /* this format should not be changed*/
Thread *ct;
begin_f_loop(f, t) /* this format should not be changed*/
ct = t->t0;
F_PROFILE(f,t,i) = ..... ;/* this format should not be changed*/
end_f_loop(f,t) /* this format should not be changed*/
modheji likes this.
msaeedsadeghi is offline   Reply With Quote
Old   January 20, 2013, 23:14
Vaze
Hi Kanarya
Please check by putting the monitor point that your inlet and exit velocities are similar or not? This is to ensure that your inlet velocities are updating at each iterations.
Best wishes
Mvee
Old   January 21, 2013, 04:11
Hi Kanarya
Best wishes
Mvee
Hi Mvee,
yes they are updating but they are different(much smaller) than outlet.
I do know why?
thanks again!
Best!
gas-liquid, horizontal pipe, slug, two-phase, volume fraction
Slug flow in a vertical pipe Abe FLUENT 0 March 29, 2007 09:01
gas solid pipe flow tahar Phoenics 6 November 3, 2003 12:03
Gas Liquid flow in a packed column Rakib FLUENT 8 June 18, 2002 01:58
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
