need help in engine simuation
Old   April 3, 2012, 10:53
Exclamation need help in engine simuation
malki
malki is on a distinguished road
Originally Posted by malki View Post
hello everybody , l'm trying to simulate my model 2D diesel engine aerodynmics induction and compression, i did the steps like the tutoriel dynamic mesh, but i found that the probleme is not in fluent it's in the mesh with gambit. my probleme exaxctely is how to define a layering zone in the two valves,and define my profil. in my last simulate i get the error like that :
error connecting mesh interface or can't creat a sliding mesh from a empty surface , and i don't understand how to connect the mesh with a layering and define the interface for sliding mesh zone , i will show you in the two pics my model , the tutoriel in the tutoriel pic we have a 1 surface with 2 mesh difirent tri and quad ? how
please eanyon can help me i'm lost , thank you
malki is offline   Reply With Quote
Old   April 3, 2012, 11:12
malki
eany body help
Old   April 4, 2012, 21:13
herntan's Avatar
YH Tan
herntan is on a distinguished road
Have you add sliding interface on this line?
Herntan,
Add Reputation if I am right
herntan is offline   Reply With Quote
Old   April 4, 2012, 21:15
herntan's Avatar
YH Tan
Have you add sliding interface here?
Herntan,
Old   April 5, 2012, 01:43
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
post a picture of your model without mesh, and display which edges are set as rigid body, interface, stationary
give also the link of your tutorial
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   April 6, 2012, 08:14
malki
hallo hentan ,tanks for you answer ;for the line , yes i did sliding interface , i think the probleme is in this line or surface , and i no know how to do
http://www.cfd-online.com/Forums/att...1&d=1333714432
you can see there is two diffirent mesh , how to create a layering zone of sliding mesh ?
Old   April 6, 2012, 08:25
malki
hello max , tank you for your answer i will give you the tut http://cfdcomputing.com/documents/fluent_tutorial3.htm
http://hpce.iitm.ac.in/website/Manua...ug/node458.htm
Old   April 12, 2012, 23:49
Default so
malki
there is no answers, i don't understand , eanybody put an idea for this
Plz help me "creation IC engine Geometry" khalaf FLUENT 8 September 28, 2016 01:10
CFD of combustion process of Homogeneous Charge Compression Engine (HCCI) kelvinlim Main CFD Forum 2 January 26, 2012 22:19
meshing of two-stroke engine in gambit ravi FLUENT 2 January 18, 2012 01:14
Need help for IC engine analysis in basic level tsram90 FLUENT 0 November 3, 2011 06:57
Boundary Conditions for aircraft engine in Fluent 6.3 Tareen FLUENT 0 July 20, 2011 00:05
