local parallel - dynamic gradient adaption
Old   April 10, 2012, 19:43
Default local parallel - dynamic gradient adaption
nazareno mancinelli
yochule is on a distinguished road
hello people!
i have a problem when i run the dynamic gradient adaption.
i run in local parallel with the next command: ./fluent 2ddp -t4 -pnet
and its running fine in local parallel.
but the problem its when i set the dynamic gradient adaption. as you can see in the screenshots, with the first adaption the further iterations runs not in parallel, so the solution take so much time....
do you know what should i do to fix that?
thanks so much in advance!
yochule is offline   Reply With Quote
gradient adaption, local parallel
CFX 13 Linux (Ubuntu 11.10) local parallel setup TSokl ANSYS 0 January 16, 2012 07:35
Errors during Gradient Adaption Nandu FLUENT 1 November 3, 2003 09:30
Gradient adaption Mohamed FLUENT 1 June 2, 2003 12:22
grid adaption on parallel Nurul Murad FLUENT 0 May 28, 2002 03:34
Gradient Adaption Jie FLUENT 2 August 27, 2001 10:26
