journal
Old   July 13, 1999, 23:28
Default journal
MYM. Rameez
How I can search for AIAA journals
Old   July 14, 1999, 00:19
Default Re: journal
John C. Chien
(1). What I normally do is : go to a library and ask a librarian for the Journals or papers. They are trained to do the search for you. When they are busy, they will probably tell you what to do. (2). Sometimes AIAA journals are in hard copies, sometimes they are in microfilm form.
Old   July 14, 1999, 02:51
Default Re: journal
Frank Bramkamp
You can find tables of contents of AIAA Journal, Journal of Aircraft etc...under:
http://www.stanford.edu/group/aiaa/n....journals.html
unfortunately the index of the AIAA Journal is only updated to 1995.
Frank
Old   July 14, 1999, 03:14
Default Re: journal
MYM.Rameez
Thanks for your kindness. When you find a latest one,please let me know
Old   July 14, 1999, 10:25
Default Re: journal
younes khamliche
Try AIAA's homepage at www.aiaa.org - Good luck
Interrupting a Journal File svp FLUENT 2 February 16, 2011 08:00
gambit journal for run a journal? Ralf Schmidt FLUENT 3 May 25, 2010 14:41
Problems With Journal When Writing Forces To File Andrew FLUENT 2 September 23, 2005 02:12
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
Gambit Journal File Scripts, Public Database Needed? Jonas Larsson Main CFD Forum 13 March 2, 1999 07:25
