Problem in applying SST k-omega
Old   May 4, 2012, 23:54
Default Problem in applying SST k-omega
Mehdi Baba Mehdi
mb.pejvak is on a distinguished road
I plan to apply SSt k-omega turbulence model in my self-developing code. I wrote a code for laminar flow and obtained reasonable and in comparison with analytical results over a flat plate, it had 4% difference in Re=90000. So I am applying the turbulence model in the code and it start to converge up to 1e-4 in 5000 iteration. but in post processing, results are not acceptable.In that, K and Omega and also U in whole domain have inlet value just in first cell near flat plate. it seems code doesn't work. I changed some part of code such as inlet and freestream value for K and omega, converting convection descritizing from 2nd order (TVD) to 1nd order (upwind), make grid finer near solid surface (y(first row)~0.002) and ... . as it is seen in attached picture K, Omega and U near the wall(knear, omeganear files) only in first row change and almost whole domain have inelt value.
does anyone know why this happen and what wrong exist in the code.
thanks in advance.
mb.pejvak is offline   Reply With Quote
Old   May 9, 2012, 20:39
Mehdi Baba Mehdi
any idea? unfortunately I can fix the problem. Infact, after 4700 iteration, my result in K and omega are still constatnt in whole domain. I change my grid to achieve Y(first row)~0.0001, but nothing changed. I am completely in my wits end.
Old   May 17, 2012, 19:50
Mehdi Baba Mehdi
finally I can fix it. problem was in under-relaxation factors for turbulence equation.
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
2D SST Simulation Airfoil - Convergence Problem Kraemer CFX 10 April 16, 2011 07:22
flow driven problem - fortran Matjaz CFX 4 April 11, 2011 13:52
convergence problem of the SST and RNG k-e model for mixing tank ziyan7 FLUENT 0 March 8, 2011 06:13
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
