May 15, 2012, 06:08 |
Turbine-99 Draft Tube geometry (CAD file)
Does anyone has access to the CAD file(s) of the ERCOFTAC Workshop turbine-99 Draft Tube geometry? This case is also the one used in the QNET-CFD application challenge AC6-07 (http://qnet-ercoftac.cfms.org.uk/w/index.php/Draft_tube). Preferred format: STL or 3D DXF - I am after the geometry/surface mesh, not the volume mesh. Thanks in advance. Julien
--- Julien de Charentenay |
November 29, 2017, 21:33 |
guoshuanghui
Have you found this CAD file?
GPU Linear Solvers for OpenFOAM | gocarts | OpenFOAM Announcements from Other Sources | 37 | August 17, 2022 14:22 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 13:14 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
