Cost of a simulation
Like Tree5Likes
Old   May 16, 2012, 19:39
Default Cost of a simulation
Edu
Edu-R is on a distinguished road
Dear all!
Yesterday I was thinking about the CFD companies, and the projects and simulations that have to do to compensate the amount of money they paid for the software.
Could anyone tell me how much cost a simulation? I know that it is a very generic question and that it can vary a lot, so I'm going to put a simple example:
Imagine that you have a car (or an airplane) modelled in CAD, and you want to know the pressure distribution over the model, velocity contours, and lift and drag coefficients, but you donīt have a CFD software, so you must go to above companies. Assuming that the CAD is properly done (no surface repairing is required), that the resultant mesh is not required to have more than 8 million elements (because k-e or k-w will be used with standard wall functions), and that is a steady simulation, how much would you pay for this information? And if you need any advice to improve your model (efficiency or whatever)?
I have no idea about how much it can cost, and I donīt need an exact values or prices. It's only to have an idea
Thanks in advance!
Regards,
-Edu-
Edu-R is offline   Reply With Quote
Old   May 16, 2012, 20:03
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Originally Posted by Edu-R View Post
Dear all!
Thanks in advance!
Regards,
-Edu-
For 8 million cells calculation and k-w model , I will only pay 150000 yen (in japan) and buy myself a 64 bit desktop. I will use iNavier and get the results.
I in fact I have done same thing in past using k-w and SA model for someone using my desktop.
SergeAS likes this.
arjun is offline   Reply With Quote
Old   May 17, 2012, 00:52
SergeAS's Avatar
Serge A. Suchkov
SergeAS is on a distinguished road
Send a message via Skype™ to SergeAS
Good point. Looks like cost of simulation it is cost of your hardware :-)
I also confirm this rule for our contracts for simulation tasks.
OpenHyperFLOW2D Project
SergeAS is offline   Reply With Quote
Old   May 17, 2012, 03:11
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
What about the software cost and man-hours ???? (70-80% of total cost)
Far is offline   Reply With Quote
Old   May 17, 2012, 03:50
Arjun
It depends on the user experience. But if grid is not very very bad, then solver usually at least converges. For the external aerodynamics , the new version of iNavier is yet to diverge for the tests i have done.
Accuracy is another thing though and solution can depend on grid and non orthogonality. I am working on this aspect and would try to create better solver.
Old   May 17, 2012, 03:59
SergeAS's Avatar
Serge A. Suchkov
Do you add cost for in-house software in to the contract ?
Old   May 17, 2012, 04:02
Far
Sijal
Ya, should be in some form. This is how business is done
But the question was related to companies (you are outsourcing) and they shall solve problem with /without commercial solvers they have .
Old   May 17, 2012, 04:19
SergeAS's Avatar
Serge A. Suchkov
There is a problem, unless the contract provided that you are the developed of software for customer, then the customer can claim the for this code. If the customer receives only the simulation results that this question does not arise, but there is a "cost of modifying in-house software" for the problem of the customer, but it is not 70-80% of total cost
Old   May 17, 2012, 04:42
Arjun
I thought by software code and man hours he means the cost of learning the solver and then cost of meshing etc.
If the solver is easy to learn cost of learning is very low.
Then meshing is the one that takes time. If mesh is too bad user will keep on getting divergence and it is time consuming.
If grid is good or solver is good enough to handle bad mesh than solution at least converges. (this is the start)
Then you are looking at the accuracy, it means the way to test if results are even good or usable.
An experienced user who understand CFD would be able to create good meshes that solver converges easily and provide accurate results. (accurate enough to be usable).
The new versions of iNavier are very stable, I have been testing them on very very bad meshes. So this part of time would be saved.
Interesting that while people spend time trying to converge, I spend time trying to create meshes that should make solver diverge. :-D
Old   May 17, 2012, 04:57
Far
Sijal
In starting of my career, I was expert at creating the poor meshes, which never converge.
Even solver (Fluent) by looking at the mesh (mesh check), I can feel it is saying Aaaargh
Old   May 17, 2012, 05:01
Far
Sijal
By software cost I mean you pay for it on yearly basis+ initial cost. And by man hours, I mean cleaning geometry, learning about problem, grid generation, solver setting and solution, validation, postprocesing and report writing.
Old   May 17, 2012, 07:02
Edu
Hi all!
First of all thank you for your answers!
I know that for the example I've put the best solution (economically) for the company will be to have a free CFD solver and learn how to use it.
Reading your answers I forgot to mention some things that could be important, so I'll modify it:
Imagine you need an accurate simulation of the model, close to y+=1, and it means that you will need a mesh of about 100 million elements. You need to know the parameters explained in the first post, but you donīt know anything about CFD, so you won't buy any software (even if it is free, because you don't know how to use). The other possibility is to go to an external company, which makes a lot of projects with CFD, and which has a computer capable to do this simulation. The problem is that they use a commercial solver (such as Fluent or Star CCM+), and they have to pay an anual license for it. It must be taken into account that the people of this external company knows perfectly how to use this software, because they have a good experience with it, and because of that, the CFD engineer defines the mesh in 2 hours, and the computer builds this mesh in 8 hours and solves the problem in 24 hours (for example). Is also assumed that the computer is already amortized, and the energy consumption cost is added directly to the final price, so we can neglect it for this example.
How much would you pay?
How much could be the €/h of the engineer (defining mesh, post-processing, etc.) and the €/h of the computation (meshing and solving)?
If there is something I've forgotten don't hesitate to comment
Regards,
-Edu-
Old   May 17, 2012, 07:39
SergeAS's Avatar
Serge A. Suchkov
I'll try to present the situation from customer's point view.
Cost of simulation is closely related to the cost of full-scale experiment because the simulation can reduce the cost (to cut the program) full-scale tests. It is natural for the customer the expected economic effect of reducing the full-scale testing program exceed the costs of the numerical simulation. Ratio of simulation cost / full-scale experiment cost is different for different areas (aerospace, automotive, etc)
Old   May 17, 2012, 08:05
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
I'll just give my 0.02€...
First of all bear in mind that my situation is not the norm for cfd consultancy: we are a very small group of cfd consultant, we don't own very larg clusters but prefer to rent the computer time, and use mostly open-source software. this allows us to keep a very low overhead and to pay for resources only on a as-you-go base.
That being said, our major cost is man-hour so the time to clean the geometry, mesh, set up the simulation, postprocess the results, write the report, wash and rinse. If we are dealing with a problem we've not encountered before there is to add a fraction of the time to prepare some testcases and validation aganist known benchmarks.
A company that uses commercial software have to pay the licences and the computer, but if it is big enough the cost will be distribuited across many customers, and I won't expect it to be a big part of the total sum.
Overall then, what you are paying for is the time, brain and experience of the cfd analyst. It is not too hard to get the results from a cfd simulations. It is to get the right results, the right postprocessing and the right feedback to improve your design.
I hope my post haven't turned out too much as a commercial.
http://www.leadingedge.it/
Naval architecture and CFD consultancy
sail is offline   Reply With Quote
Edu
Dear SergeAS,
Thanks for your answer!
I know that the cost depends on multiple factors, and that's why I've put an example as complete as I can.
The aim of the question was to know an order of magnitude of the cost. I mean, to know if the simulation could be in the level of 1k, 10k or 100k € (or maybe 100€ ). I donīt need to know (and we can't) that it would cost exactly 2565€ (for example), because we can't calculate it due to the lack of few parameters: we (or I) don't know the cost of the software (which vary a lot), the power consumption cost, etc.
If you tell me "Ok, if you are going to ask to a company to do this simulation they could charge you around 50k€, because it is a normal price" (for example), I will be happy, even if the simulation cost 25k or 60k, because I will have an order of magnitude of the cost.
However, all the answers and information are welcome, so thank you again for your answer!
Regards
Old   May 17, 2012, 08:20
Edu
Dear sail,
I agree with you at all, especially with the text marked
ŋCould you tell me (if you can or want) how much costs for a customer an hour of work of a cfd analyst (not how much he/she earns per hour, which normally is different)?
Regards
Old   May 17, 2012, 23:43
Martin Hegedus
Martin Hegedus is on a distinguished road
Are you looking for an aero/fluid dynamicist or a CFDer? Are you looking for design support or an analysis? In general an aero/fluid dynamicist is more expensive than someone who runs a CFD code. The aerodynamicist will oversee what the CFDer does, if they do not do the work themselves. The cost of an aero person is about 2x to 3x their salary. So take what you think the yearly salary of a professional of the caliber you are looking for should be and multiply it by 2.5.
One of the first things you and your aerodynamicist should do, before you even touch a keyboard, is to determine what physics are involved with your problem. The more non linear and/or sensitive your problem is, the higher the cost and uncertainty will be. In general, outlining the physics should not take much time and should be inexpensive. A good aero/fluid dynamicist should basically be able to quickly sketch out the problem for you. That sketch(es) will then be the foundation of the work plan.
If your problem has a lot of uncertainty then a big part of the cost will be how much you want to drive down the uncertainty or determine what the uncertainties (error bars) are. Depending on what your project is, some control systems need accurate models of the plant.
Another item to be aware of, and I'll be straight forward here, my experience has been, in the case of design projects rather than just analysis, that when a client, without some fluid dynamics background or support, comes to me with a design already established, there is a chance that things do not go according to the clients wishes. Frequently, they find the performance of the design not meeting their expectations. And sometimes, for various reasons, they are hesitant to change the design in a meaningful way. Trying to fit a square peg in a round hole, so to speak, becomes VERY expensive. And, frankly, it is a cash cow to an aerodynamicist.
Far and SergeAS like this.
Martin Hegedus is offline   Reply With Quote
Old   May 18, 2012, 00:20
Martin Hegedus
@Edu-R
Just for fun, you mention "Imagine that you have a car (or an airplane) modelled in CAD, and you want to know the pressure distribution over the model, velocity contours, and lift and drag coefficients"
So, as an aerodynamicist, I'm going to ask you, for what do you need the pressure distribution, velocity contours and CL+CD for? And why use CFD? For example, in regards to CL+CD for a car, what will the added accuracy by using CFD rather than historical knowledge give you?
Old   May 18, 2012, 01:17
Far
Sijal
Great. This explains the whole story.
Old   May 18, 2012, 16:05
Edu
Dear Martin,
The first aim was to know the cost of a simulation done by a CFDer, but there is no problem to know also the cost of aerodynamicist
This is the datum I was looking for, even without exact values Thanks!
Totally agree, especially with the last paragraph
@Edu-RJust for fun, you mention "Imagine that you have a car (or an airplane) modelled in CAD, and you want to know the pressure distribution over the model, velocity contours, and lift and drag coefficients"
Another example:
A small company, that does a little number of cars (those companies that make the cars "by hand"), has one designed, and the owner doesn't want to modify this design because it is visually nice (for example). Maybe he wants to know the pressure over the bodywork to have an idea of the force applied over it, and thus, the deformation that it would suffer, or maybe he wants to know this datum to calculate the thickness of material they have to put in order to obtain a desired deformation or to achieve the less weight as possible.
It is strange, and maybe a bit irreal, but it can be possible
Thanks again!
Regards,
-Edu-
Why my simulation not agree with the wind tunnel experiment zhaowei CFX 4 July 11, 2015 03:36
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 14:29
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
