Need Help on Gaseous Urea Injection in FLUENT
Old   July 11, 2012, 16:57
Default Need Help on Gaseous Urea Injection in FLUENT
Mosi Owa
BMCombustor is on a distinguished road
Hi everybody,
Does anyone have any experience with gaseous urea injection in FLUENT? I'm working on urea injection in a boiler furnace (SNCR) and confused with my result. First I calculate flow field with urea injection, but when I switch to FLUENT NOx calculation module and set SNCR properties, I don't get good result. It seems that urea injection has absolutely no effect on my NOx reduction! While the urea is completely consumed, but my NOx out flow rate (from stack) doesn't show any change. In addition, during solution I see only the plot of urea and HCN residuals; while there are other pollutants in the legend (located at top left of residual window) like as NH3, N2O, HNCO and NCO, but there is no residual plot for them (I select all of them in my equation list). Their values are also zero when checking them on their graphical contours. It seems that fluent does not calculate the rate equation for them!!!
Any clue is highly appreciated.
BMCombustor is offline   Reply With Quote
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Error in reading Fluent 13 case file in fluent 12 apurv FLUENT 2 July 12, 2013 07:46
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
