July 18, 2012, 02:50 |
SITVC calculation
I am doing calculation on Secondary Injection Thrust Vector Control (SITVC) using Pressure inlet at the primary nozzle. Later I have to use mass flow rate instead of pressure inlet. In the calculation , I am using secondary injection port having different pressure inlet condition on that Port. My question is how I can use the mass flow rate in the primary nozzle and how I can use pressure inlet in secondary port in the Fluent calculation. Although I can do the calculation using the pressure inlet in the primary nozzle. Thanks in advance. |
Transfer output data as input for second calculation | mannobot | Main CFD Forum | 3 | December 7, 2018 09:37 |
Questions on Boundary Layer Spring Method for 3D Calculation | didiean | FLUENT | 15 | December 18, 2014 21:09 |
MRF and Heat transfer calculation | Susan YU | FLUENT | 0 | June 2, 2010 08:46 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
Heat Flux Calculation under REPORTS | Alberto Schroth | FLUENT | 0 | May 16, 2000 08:19 |
