SPH boundary & discontinuity correction terms |
July 9, 2012, 06:47 |
Tarek
Rep Power: 13 |
I'm working on a CFD Matlab code using smoothing particle hydrodynamics (SPH) approach.
I have a great problem with the consistency at the boundaries & the discontinuities due to Shock waves. They make the code results totally wrong. I've tried to add terms for normalization & correction defined by (Liu) & (Chen) in the governing equations but I fail to get right answers. Could anyone help me how to use the normalization & correction techniques in Navier-Stokes equations especially in discontinuities |
July 27, 2012, 06:15 |
Daniel Barcarolo
Rep Power: 13 |
What are you using to model your boundary conditions??
July 27, 2012, 06:26 |
Tarek
Rep Power: 13 |
I used virtual exterior particles to mirror the fluid particles near the boundary. I didn't use boundary virtual particles.
Now I achieved the right results near the boundary. But in the wave discontinuity, I have an inaccuracy in result (represented in form of varying non-smooth results for a flow). |
July 27, 2012, 06:36 |
Daniel Barcarolo
Rep Power: 13 |
So you have used ghost particles...?
And are you also using Artificial Viscosity SPH? |
July 27, 2012, 06:38 |
Tarek
Rep Power: 13 |
Yes I used Monaghan Artificial Viscosity
July 27, 2012, 06:46 |
Daniel Barcarolo
Rep Power: 13 |
As far as I know with AV SPH you will always encounter some problem with your results. If you want more quality and precision you should look for preciser variants of SPH like Riemann-SPH and delta-SPH...
July 27, 2012, 08:05 |
Tarek
Rep Power: 13 |
OK I'll check & try that....many thanks
Display Modes | |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 09:56 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 18:15 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 22:25 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
Boundary Conditions | Jan Ramboer | Main CFD Forum | 11 | August 16, 1999 09:59 |
