contour plots
Old   December 28, 2005, 02:21
Default contour plots
Rits
Can anybody tell me what exactly is the contour plot and how to draw them using gnuplot. I am trying to slove 2-D eular equation for shock reflection problem. I have data file with columns x,y, u(x,y) at final time t. I trid "splot" for ploting the data file, but I could not get the reported graphs in various research papers. Can somebody tell me what should I do?
regards Ritesh
Old   December 28, 2005, 03:22
Default Re: contour plots
Praveen. C
At the gnuplot prompt, type "help contours".
Old   December 28, 2005, 12:31
Dr. Tiger
Contour plot allows you to visualize the level curves.
For three dimensional plot ie(let f be a function of two variables) and let c be a constant. The set of all (x,y) in the plane such that f(x,y) = c is called a level curve of f with value c.
You can think of a mountain or hill and slicing horizontally and mapping each of those slices. This gives you some idea of the slope. The closer the lines are the steeper the slope.
Hope this helps,
~Dr. Tiger
Old   December 28, 2005, 13:29
Rits
Thanks for the information, actually I have got the method through which we can draw contour plots using datafiles in gnuplot. following is the link http://www.gnuplot.info/faq/faq.html...00000000000000 It work for me. Hope sombody else find it useful.
CFX Contour Plots Troubleshooting derz CFX 7 November 21, 2010 10:08
vector plots and contour plots do not match swati_mohanty FLUENT 1 August 26, 2010 05:53
How to change contour plots Pedro Romero FLUENT 4 November 19, 2009 00:14
drawing of contour plots chinthakindi Main CFD Forum 1 April 27, 2004 04:33
Local surface contour line plots Nandu FLUENT 0 November 9, 2003 23:26
